Left vertical Area unresponsive
I bought a uses nexus S and found that it had an unresponsive to touch area of the screen. This area is a 1cm large rectangle.
Which parts should i replace to get back a fully working screen?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Montasser Ben Gadri, usually when the digitizer (touch) is unresponsible at a certain area of your screen, it is the digitizer that needs to be replaced.
Bu yanıt yardımcı oldu mu?
Thank you very much for your answer. Is it easily replacable? Where do i find the cheapest place for nexus s digitizers?
Thank you for accepting my answer. Sorry, nothing is ever really easy, but it is not a bad job. Check on the teardown Nexus S Teardown it does give you a good idea what's involved. You can also check om here http://www.repairsuniverse.com/samsung-g... As for the cheapest place, it really depends on your geographical location.I tried Google and average price ~$120....Hope this helps.The reason for that is cause the Digitizer and the LCD are a lot easier to change as one unit....
http://www.ebay.co.uk/itm/New-OEM-LCD-Sc... $80... but it's from china, so you'll have a wait on delivery.
Thank you for your great help.
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 763
