windshield washer reservoir is leaking
I have a 2007 Mazda 3 and the windshield washer reservoir has been damaged by hitting a curb. What is the easiest way to replace it? The bumper appears to be undamaged.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Nothing easy about it....:-(
WASHER TANK REMOVAL/INSTALLATION
1. Disconnect the negative battery cable.
2. Remove the front bumper. (See09-10-8 FRONT BUMPER REMOVAL/INSTALLATION.)
3. Disconnect the windshield washer motor connector and windshield washer hose.
4. Disconnect the rear washer motor connector and rear washer hose.
5. Disconnect the washer fluid-level sensor connector. (Vehicles with the washer fluid-level sensor)
6. Remove the bolts and nut, then remove the washer tank.
7, Install in the reverse order of removal.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 14
Her zaman: 3,608
