Ana içeriğe geç
4 Kasım 2017'de satışa sunulmuştur. Model A1865, A1901. GSM ya da CDMA olarak 64 ya da 256 GB kapasitelerinde, Gümüş ya da Uzay Grisi renklerinde satılır. ("iPhone 10" olarak da telaffuz edilir.)
Microphone problem after screen replacement
Hello.
When I replace the display with a new LCD, then I screw the tape with (speaker-microphone-face id etc), while recording the front camera I hear a slight squeaking in the background. But when the tape is on the outside of the screen, it is all ok. Is it maybe some kind of lack of grounding in the screen? Is there any method to change it? (in the original display everything is fine) Any suggestions or help are welcome.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Yes, I checked everything. This little golden clip does not eliminate the problem. Flex is ok, everything works fine on the original screen.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Did you place back the little gold grounding clip as can be seen in step 22 of this guide? iPhone X Screen Replacement
Also double check the flex cables to ensure they are not damaged.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
tarafından
Yorum Ekle
I have 350 of the same replacement displays, I checked 30+ lcd's and they all have the same problem. (little noise - “piiiiii” when i recording front camera)
Puan 0
Yorum Ekle
This is an issue with bad quality replacement frames. Sometimes it is easier to use a good quality screen to save the hassle.
Puan 0
2 Yorum:
So you are saying that in my replacement displays, weak aluminum or other metal was used during production, which interferes incorrectly with the phone casing?
tarafından
Yes exactly.
tarafından
Yorum Ekle
Yanıtını ekle
Lucas Szeyk sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 640
