Ana içeriğe geç
Repair your Dyson V7 Motorhead vacuum with a part replacement guide.
Dyson v7 Motorhead flashing red lights and not charging.
Hello, my Dyson v7 motorhead isn’t charging. After pressing the button to use it, the vacuum would flash a red light at the bottom for a short while before shutting off. The same happens upon plugging it in. Does anyone know what is going on, if so how do you fix it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
first check if its over 12 blinks or less if more its the battery if less its the motor so if its more you need to replace the battery if less search it up
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Hello, I changed the battery but the same problem occurred a second time, what could it be? Same red flash, new battery
tarafından
Yorum Ekle
Sounds like you probably need a new battery. If it flashes red 10 or fewer times, the Dyson website says you need to contact them. But if it flashes red 12 or more times, then it's just a dead battery. Order a battery here on iFixit. I'm waiting for mine to arrive tomorrow.
Puan 0
Yorum Ekle
Yanıtını ekle
Michelle Mills sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 20
Son 30 gün: 84
Her zaman: 7,274
