Ana içeriğe geç
The Kenmore Elite HE3 is a washing machine by Kenmore.
669 Soru Tümünü görüntüle
Why does my rubber drain hose stick together?
I've made sure there is no clogs anywhere. I then removed my pump and brought it to an appliance repair technician. He hooked the pump up to and identical machine and told me that the pump was in great working condition.
But every load I do when it goes to drain the rubber hose that goes from the tub to the pump suctions together. Which makes the draining process to slow which puts it into an F02 code. Why and what now?
Please help me
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
So 1 of 2 things are happening. You have a clog or your hose is old. For the hose to crush like you're saying there has to be a pressure differential...likely being created by the pump. The fact that the hose is crushing means the pump is working fine, there's a clog up stream. You said you made sure that there are no clogs, how did you do this? Is it possible you missed a clog? Or maybe a clog can be caused by the clothes in the machine (sorry I haven't handled one of these machines up close and personal).
If the hose is old, it could be weak. Also, if it was (or is) kinked, it could be damaged or at least soft in that kinked spot, allowing for easy crushing. Make sure the hose is in good condition, or try just replacing it. Hose is cheap!
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Tonya sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 508
