Ana içeriğe geç
Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
552 Soru Tümünü görüntüle
late 2013 MacBook Pro board can be replaced with 2014 or 2015 board?
My late 2013 MacBook has too small memory. (4gb)
While I was looking for a way, I wondered if I could change the board and solve it. If it is the same A1502, I think the external case will be the same. (screw, usb port, etc..)
As far as I know, when dividing A1502's model into two categories: 2013-2014, 2015.
  1. A. If I replace it with the 2015 main board, will it be possible to assemble it?
  2. B. If it is impossible, would it be possible to replace it with a 2014 board?
According to the investigation, I heard that there are some problems.
  1. Battery is different between 2013 and 2015, but current battery is 0%, so even if 2013 is used continuously or changed to 2015 or 2014, it needs to be exchanged.
  2. There is no need for additional function of touchpad.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Sadly there are too many differences that prohibit switching out the logic boards between your 2013 with either the 2014 or 2015 board.
The cases are different around the trackpad as your 2013 model uses a very different design than the 2014 and you can’t use the older trackpad.
Review these two teardown’s:
MacBook Pro 13" Retina Display Late 2013 Görseli
Kılavuz
MacBook Pro 13" Retina Display Late 2013 Teardown
Zorluk:
Orta
MacBook Pro 13" Retina Display Early 2015 Görseli
Kılavuz
MacBook Pro 13" Retina Display Early 2015 Teardown
Zorluk:
Orta
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
daegeun sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 22
