Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
Home button dead after battery replacement
Hi, I replaced the battery of my iPhone 7 which worked fine. But now the homebutton is completely dead. No touch id no button functionality. I already disconnected all 3 screen cables and the home button connector on the screen assembly but no luck. Still not working. Hard reset via power and volumen down button also didnt help. No errors from iOS did pop up. It is running iOS 14.4. Any further ideas? Thanks.
Bu iyi bir soru mu?
Puan 2
1 Yorum
I "HAD" same problem after replacing the battery in my wife's iPhone 7.)
SOLUTION: Reseat the flex cable connectors into circuit board sockets.
SCENARIO: I knew I had been very careful with the flex cables, so I doubted that I damaged them as was implied above. And the cable connectors "appeared" to be seated okay but the Home button would not work. I discovered that I apparently not FULLY seated the flex cables connectors back to the logic board sockets.
FIX: I removed the metal connector bracket that covers the connectors, carefully lifted the connectors out of their circuit board sockets and very carefully repositioned them slightly (again) and pressed firmly until they "clicked" in place. Yureka! The Home Button began functioning. Saved $70-150 for a new screen!
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
You have damaged the home button flex while removing or replacing the screen. This is the flex cable that goes from the screen to the logic board. They usually develop a small tear at the 90 degree bend and sometimes will require magnification to see.
You will need to purchase another screen.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
That sounds pretty legit. I assume the flex cable is not available as spare part or is not replacable separatly?
tarafından
Unfortunately they are not replaceable.
tarafından
WAIT! TRY THIS FIRST! (I "HAD" same problem after replacing the battery in my wife's iPhone 7.)
tarafından
Yorum Ekle
If it’s a battery issue then try using the old battery to see if your home button is working, if it still does not work you will need to change the home button since the cable is very Delicate. But if you change it you will have no touch id.
Puan 0
Yorum Ekle
Yanıtını ekle
alio sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 285
