Ana içeriğe geç
Part of Google's third generation of Pixel phones, the 3a is a budget-minded option with the same camera as Google's flagships. Available in Clearly White, Just Black, or Purple-ish. Released May 2019.
70 Soru Tümünü görüntüle
Help with screen replacement adhesive
I have bought a replacement screen for my pixel 3a to change out my current, broken, one. The screen did not include any type of adhesive. I’ve seen multiple options online, for example the ifixit kit comes with either a custom cut out adhesive or tesa tape, I’ve also seen that some kits ship with some type of glue. What is my best option to re attach the screen?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Glueing it in is going to make it very difficult when it’s time to change the battery.
I’d use some adhesive strips like these:
[bağlı ürün eksik veya kapalı: IF180-007]
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Hi Simon,
I would use B-7000 glue, which is a slow drying compound, that allows you to perfectly align your screen after replacement. It also cleans up well, leaving o residue on the screen or frame after assembly.These tubes come with a precision tip, which helps with the accurate application.
Hope it helps!
Puan 1
Yorum Ekle
Yanıtını ekle
Simon Bottini sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 11
Her zaman: 267
