Ana içeriğe geç
2016 yılında piyasaya sürülen, model numarası JU6800 olan 50, 55 veya 60 inç UHD Samsung TV'ler için onarım bilgileri ve sorun giderme.
Top half of screen is dark
Top half of the screen keeps going dark, and have little bright shadow on the screen
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi Mark, I have a Samsung UE50JU6800 that has just developed the same issue.
Resim
Whilst i dont have a definitive answer yet, i found a video from Shivamm Rane on youtube ( a search on Youtube will find it, unsure of iFixits rules on links ) that details replacing either the entire LED light strips or individual LEDs on Samsung TV’s that cause this issue. It will be a few weeks before i attempt my repair but hope this helps you on your way.
The replacement LED strips seems quite readily available on Ebay.
If i am successful in my repair will post a guide.
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
Was the repair successful?
tarafından
U mnie jest na odwrót na dole jest ciemniejszy ekran
tarafından
@szmondjabin in that case your bottom backlight strip has failed. Replacing it should fix that.
@szmondjabin w takim przypadku uszkodzony jest dolny pasek podświetlenia. Wymiana powinna rozwiązać problem.
tarafından
Yorum Ekle
Yanıtını ekle
Mark Broadbent sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 29
Her zaman: 1,165
