reason for replace a joint boot
Does a broken join boot will be responsible for a power steering fluid liq?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
No it does not. If you have a leak of power steering it is usually caused by as failed gasket/O-ring in the system, like the steering gear, the pump, or any of the hose. The boot is there to protect the rack and pinion gear from debris entering the the steering gear. You can download the suspension and steering part of a repair manual from here. Good Luck
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 434
