VCR calendar only goes to 2020
What can I do if my VCR's calendar only goes to 2020 and I want to do timer recordings?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi @rdenike ,
I have done some digging on the web and found this website which probably relates to your issue and may offer some sort of solution.
I think you need to change your actual calendar on the VCR back to the first ever year with the same starting day (according to the list on this website and then everything afterwards will fall in place. It has a running year generator so you will be able to match the years your VCR is capable of handling.
https://calendarhome.com/calculate/find-...
Hope it helps!
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 25
