Ana içeriğe geç
Xiaomi bünyesindeki Amazfit'in kare şeklindeki plastik akıllı saati. 2017 yılında piyasaya sürülmüştür.
Battery replacement on Bip
Does aynone tried to replace the batteriy in the watch? It seems my watch battery capacity reduced. Last depleeting cicle took only 15day but usualy it took 30-45day to drop to 15%. What kind of battery can be used to replace the original?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Replacement Bip battery
https://www.ebay.co.uk/itm/204240393865?...
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Hi there! The battery used on the Bip (model A1608) is a 200 mAh lithium ion battery. I’ve also been having issues with my Amazfit smartwatch regarding battery charge depletion. I think it may be something to do with your plug adapter or the fact you may have left it on the charger a bit too long after it reached maximum charging capacity.
Puan 0
1 Yorum:
I think it's the BMS. Mine drains in 5 minutes but you can still turn it on with long press. Then recharge for minute and it says 90% again.
tarafından
Yorum Ekle
I suspect this is some software update result not really the battery. I already bought a bips and that have even shorter battery (tooks about 9day to depleet). So the old bip sits in its onw box. After about 6mo I checked what is the battery status and put on charger it was about 85%. If the battery would bad I suspect it would not even turned on.
Puan 0
Yorum Ekle
wher can i get amazfit bip u pro battery.???
Puan 0
Yorum Ekle
Battery replacement
Puan 0
Yorum Ekle
Yanıtını ekle
Dimitryj Tyer sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 19
Son 30 gün: 75
Her zaman: 4,920
