Ana içeriğe geç
Model Number A1707. Released June 2017, this MacBook Pro features Kaby Lake processors up to the 2.8 GHz quad-core Intel Core i7 processor with Turbo Boost up to 3.8 GHz.
327 Soru Tümünü görüntüle
touchbar not working after battery replacement
hey
i hope someone can help:
i changed the battery on my mbp 2017 15”. did it with the ifixit guide und battery. auto boot has been switched off prior to the repair.i already tried the smc rest and pram reset shortcuts etc.
Everything powers on, but the touch bar wont come to life. i have reconnected the touch bar display and digitizer cables carefully. I have never bent them hard during the process, the were otherwise untouched. the contacts look fine, cleaned everything with air. i have redone the whole procedure carefully - it still does not power on. The Touch Bar is not shown in the keyboard menu and there is no Touch Bar process to pkill.. So I guess its not communicating / seems to not be connected even though the cables are connected just fine..
Before exchanging the battery everything worked properly. I changed the battery because it was not holding a charge for more that one or two hours and had been used daily for the past 3,5 years.
any ideas how to solve this?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
You'll need to get a USB-C power meter to monitor the power. You likely have a bad charging chip
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Was your Mac functioning OK except for a weak battery before you replaced it?
Can you power the laptop on with the battery disconnected?
Bu yanıt yardımcı oldu mu?
Puan 0
6 Yorum:
hey, yes it was working normally before. I have updated my thread as I managed to power it on but now the Touch Bar is not working. best, jan
tarafından
Is the battery you bought original? Try reinstalling the old battery temporarily to see if you have full functionality again. If so, The battery is to blame. Cheap and poorly manufactured batteries can cause havoc with the SMC and cause a multitude of issues. The SMC and power management are very closely related to each other. I have seen MacBooks grind to a halt with the beachball of death and the battery was to blame.
tarafından
@janeric - Try resetting the NVRAM Reset NVRAM or PRAM on your Mac You may also need to reset the Touch bar logic Mac: How to fix and restart the Touch Bar when it stops working
tarafından
@danj - unfortunately I have already done that. does not help. but thanks !!
tarafından
@duvelhedz it is the "original" bought here from ifixit. I will give it a try an connect the old battery to see what happens ! thanks!
tarafından
1 tane daha yorum göster
Yorum Ekle
I know is an old post but a lot of people including me have this problem. To solve this problem, I tried all sorts of things.  knowing that I was very careful when I changed the battery and keyboard, so I ruled out that the problem was a physical one.  I knew from the beginning that it was software.  So, I discovered that if you watch youtube in full screen mode until the battery is completely discharged and then you charge it, after about 30 minutes you turn it on the MacBook , but it must be plugged in charger, you will have a pleasant surprise  , your touchbar has started and will work without any problems.
Puan 0
Yorum Ekle
Yanıtını ekle
jee sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 40
Her zaman: 1,104
