External USB Camera keeps turning on and off (see video)
I have a Sony camera connected via the elgato camlink stick. Everything worked fine, until I plugged in a multi-usb adapter. Then this strange behaviour you can see in the video occured, forever :(
Here are some logs
- Turned off and on
- Tried another Macbook (same behaviour there, very strange)
- I reset the SMC and PRam.
Update (03/24/2021)
Hi guys, thanks for your support!
I do not know why, but it works.
I changed the adapter and everything works fine. That is weird, because everything worked fine with the adapter that I exchanged. Thanks for your thoughts @logixal, inspired me to adjust a cable.
I am not sure if this will help anyone out there, as my setup is quite specific.
But what I can tell (if someone stumbles upon these error messages) that this must be some software related issue. I am not sure, if the third party usb hardware that I have plugged in updated my usb drivers. Being uncertain, my next step would have been @danj s advice, speak to elgato / apple and sending them some of my logs (spotlight -> console).
Bu iyi bir soru mu?
3 Yorum
What happens when you directly connect the Elgato Camlink stick to your system? Or another system which has a USB-A port.
Dan tarafından
@danj Hi Dan, everything works fine on my Windows (direct USB-A connection). But I am pretty sure it is not an issue with the adapter (worked fine before). I think it is a problem with my Macbook. I uploaded a screenshot with some logs (console).
Alex Friedl tarafından
glad you got it working!
Logixal tarafından
