Ana içeriğe geç
iPod nano is nonresponsive
ipod nano completely dead ......not responding whn put for charging ....it had nt been used for a while .... so whn i pluged it in fr the first time to my laptop it turned on and itunes also recognised it ....but thn nw it dosent respond only .....it displays nothing on the screen ....and whn u charge it fr a long time the rear panel heats up ....how should i turn it on ???? .....how to revive it ???? ...plzzz help.......
Bu iyi bir soru mu?
Puan -1
1 Yorum
plzz respond asap .....
and troubleshooting .restarting ....turning on and off the hold button does nt work ....!!!
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
First step, clean out your dock connector. Blast it with compressed air and try reconnecting.
If that doesn't work and your iPod had worked fine before, my bet would be on a dead battery. You can buy the batteries here and use our guide for the procedure.
It could also be a bad dock connector, but I would eliminate the battery first. Good luck and let us know what happens!
Replace a battery compatible with the third generation iPod nano. Model #616-0337. 400 mAh. Installation requires soldering of battery to logic board. Görseli
Ürün
iPod nano (3rd Gen) Battery
$13.99
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Danai Bavishi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 2,017
