Ana içeriğe geç
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
Early 2013 MacBook 15" Retina display hinge replacement
Hi All,
I am trying to replace both broken hinges on my Early 2013 Macbook 15” Retina. I have all the necessary parts in hand and have separated the display from the body successfully. Now, however, I have hit a snag: I can find no disassembly instructions for removing and replacing what I believe must be the WiFi wire. Any links and/or tips? Thanks for any help!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Sorry we don’t have a guide, all we have is this MacBook Pro Retina Display Teardown for reference.
Bu yanıt yardımcı oldu mu?
Puan 1
15 Yorum:
Thanks! I only hope this doesn’t mean I have to tear the display apart to replace wires...
tarafından
Yep! You do ;-{
The better direction is just replace the entire lid assembly 15" MacBook Pro Retina Display Assembly, Apple P/N 661-7171
tarafından
Sadly, I fear you are correct. All for a 1/4" Retina connector that won't go through a lid hinge. Shame on Apple. And any display disassembly looks doomed to disaster. However, here's what I think I will do (less than optimal, but reasonable): I will try to untangle and keep the old Retina wire as well as the new replacement one. I might be able to adhere them adjacent to the laptop lid without cutting them. No more onboard camera, but everything else will work. If there only was such a thing as a male-to-male Retina plug adapter...
tarafından
@dschind - As much as I would like to tell you that would work, it won't! The camera cable also carries a voltage and thermal sensor which if you disconnect will cause your systems SMC to throttle the CPU and ramp up the fan.
tarafından
Thank you so much for your contribution! This has given rise to one other (maybe crazy) thought. What if I can succeed at prying apart the hinges themselves enough to swap new-for-old? Then I can leave the cabling untouched and functional. Very tricky at best, but...
tarafından
10 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
dschind sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 504
