Ana içeriğe geç
The Nokia N8 is the first device to run on the Symbian^3 mobile operating system and Nokia's flagship device of 2010.
How to install chinese language in n8?
i got a n8 and it cannot show chinese language,how can i install myself?
Bu iyi bir soru mu?
Puan 1
2 Yorum
how to install chinese language in Nokia N8
tarafından
check out old turkey's answer.. if you want more help then you should start your own question.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You can check and see what language are available to you by
Select Menu > Settings and Phone > Language .
Change the device language
Select Phone language.
Change the writing language
Select Writing language.
Activate predictive text input
Select Predictive text.
If you do not have Chinese in the option, then you need to have the language pack containing Chinese installed at your local Nokia Care Point. Problem is that you will lose this language pack everytime you update the firmware. The phone will always revert back to its original language pack.
Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Suettheng sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 4,133
