Ana içeriğe geç
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
Unable to use boot key combinations
Hi, I’ll try to explain all details so that somebody is able to help me, hopefully:
I own a MacBoor Pro 15’’ Retina Late 2013. I’ve replaced that SDD with a new 2TB one. but that time I was using Mac OS Catalina. right after that I installed windows 10 using Bootcamp. Some time later I’ve upgraded to Big Sur and everything continued working fine.
Recently I had some issues with windows due to being testing a lot f experimental software. so I removed BootCamp to be able to reinstall Windows 10 again using Bootcamp. But Windows 10 installation doesn’t start and the screen stays black for hours.
To try and overcome that I decided to try to go back to Catalina as with that version I never had any issues with bootcamp. But after created the USB installation media (MAC Extended Journaled) I’m not able to boot it. Neither through System Preferences -> Start Up disk nor through Start Up manager. I’m not able to go to Startup Manager as no Start Up key combinations are working, apparently. Eventried to reinstal from Internet Recovery but it always boots to the OS.
During all those actions I also realised that it seems that I have no recovery partition.
Thanks in Advance,
Antonio
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Check your keyboard input: Preferences > Keyboard click on Input sources make sure you have the correct keyboard listed in the left column (U.S.)
@abasilio To see what your drives are its easier to access your System Report via About This Mac. Now drop down to the USB to access the thumb drive, here I’m accessing a FireWire drive
And here I’m accessing the internal drive
Within Disk Utility you must alter the View to ‘Show All Devices’ Then you should be able to see the top level of your drive, In my case that would be the Samsung SSD and clicking on erase to clean things off when you add the partition you’ll be able to select the format of the partition.
Bu yanıt yardımcı oldu mu?
Puan 0
15 Yorum:
Hi Dan, thank you for your reply, but unfortunately didn't work.
tarafından
Sounds like your drive is really messed up! Time to create a bootable external drive which you can setup as the boot drive so you can fully wipe your internal drive down.
tarafından
I tried that, but I'm not able to boot the external drive. No start up key combination seems to work.
tarafından
@abasilio - You'll need to alter the boot drive via the Preference settings - Startup Disk.
tarafından
tried that too, the bootable drive doesn't show there to be selected. Tried with 2 different USB drives.
tarafından
10 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Antonio Basilio sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 156
