Ana içeriğe geç
Samsung's flagship phone, the Galaxy S8. Released in April 2017.
304 Soru Tümünü görüntüle
Battery health is still show less after new battery replacement
If you see the screenshot that indicate that battery health is 83% after replacement of brand new replacement battery. Is that poor new battery or something else? How we can make 100% battery health ?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
6 Yorum
Is the replacement battery a genuine replacement part from Samsung or a third party?
tarafından
It is Third party not original one.
tarafından
@irepairman If the rest of your device is functioning fine, then you may have just received a bad battery unfortunately. Are you able to try another battery in the device, preferably a new Samsung battery?
tarafından
I put new battery but still it shows weak
tarafından
I have the same issue with s10e I have tried 3 new batteries so far. Still I hav the issue .... any ideas
tarafından
1 tane daha yorum göster
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
This is because the battery cycle count has not been reset. In order to reset it, you either have to root your phone or have an authorized repair center like UBreakIFix to do it, which they charge $50~ to do so.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
When you replaced it did you allow the battery to cycle fully a few times? Charge to full, discharge completely, then charge again. Do this a few times. When it dies, turn it on again and let die again. Do this until it fails to turn on (screen should just show battery is at 0%) once it does charge to fill, and let die again. When replacing lithium batteries from what I've experienced you have to cycle the battery to get it fully functional. Otherwise could be a bad battery.
Puan 0
Yorum Ekle
Samsung think it will be better for them to make step against right to repair even when customer buy original OEM battery, do we really own our phones ?
Puan 0
Yorum Ekle
Yanıtını ekle
iRepairMan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 15
Son 30 gün: 65
Her zaman: 2,664
