Ana içeriğe geç
Model A1237 veya A1304 / 1.6, 1.8, 1.86 veya 2.13 GHz Core 2 Duo işlemci
Mac OS X cannot be installed on this computer
I installed a Samsung 120 GB harddrive from iFixit. Removal and installation was easy with iFixit. The previous drive was bad. I erased the new harddrive with Disk Utility and selected the recommended MAC OS Extended (Journaled). The new drive shows with the named partitioned file. I installed the original Macbook Air installation disk 10.5 in the Macbook Air external Super Drive. When I attempt to install I get the above message. I Erased again, got the same disk info,/Volumes/xxxx's Airbook, format Mac OS Extended (Journaled), 3 folders, 3 files 111.4GB available, Verify disk is OK.
I also have a new 10.6 installation disk but I can't get the 10.5 disk out of the external drive.
Why am I getting the "cannot install on this computer" message and how do I correctly install the 10.5 software?
How do I eject a startup disk from the external drive when the install disk is not available to Eject or the Drive itself cannot be ejected because the disk could not be unmounted?
Thank you
Bu iyi bir soru mu?
Puan 4
2 Yorum
Thank you Mayer. I's sorry, I used the wrong word. I did not partition my new drive, I erased and formatted in MAC OS Extended (Journaled) only.
I still could not get the original disk that came with the macbook Air to install. Thanks for the key to eject the disk. The Snow Leopard 10.6 disk installed properly, I've just completed the Time Machine restore and I think everything is good. Thanks again
tarafından
Glad I could help solve your problem ;-)
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Start up holding down the mouse button to eject the disk. When you format the drive make sure it is GUID when giving it one partition. Remember to start up from the optical drive by holding down the "C" key.
Bu yanıt yardımcı oldu mu?
Puan 9
Yorum Ekle
Just had same problem. Answer was simple but not obvious.
You have to QUIT utilities.
I believed I had to restart.
Good Luck
Puan 1
Yorum Ekle
Ok, I don't consider myself to be a newbie at this by any means... but I've run into a road block.
Instead of starting a new thread on the same question, I will piggyback on this one...since it's the same software issue.
I have a 2008 MBP A1260 with 4GB of RAM. I was running 10.9 with no issues.
Backstory: One day, no sure why... I got a fuzzy/static look upon startup. This is similar to what I've seen with water damaged machines...
I opened the machine to inspect and dry... no visible signs of liquids or charring.
I was unable to start up normally but was able to get in via LauchDaemons in Single User Mode.
I ran many many fsck -y in single user mode to get it to only 2 files and directories that were out of order. This only worked for a few days before I got an error that ran continuously until the power was pulled saying that there was a run time error and that fsck should be run on next boot. This happened the day before my new HD arrived. I was planning on installing the OS on there and booting from that and performing a clean install.
It wouldn't have mattered... the USB ports are not recognizing the external as a HD. It will charge the drive and cell phones...but will not show up in DU as an external.
Because I was booting from the HD, I could not adjust the partition, fully repair, or reformat the HD. I could not get the machine to boot into internet recovery mode or to the hardware test. NAVRAM rest key sets worked along with the C key to choose boot drive... but not Ctrl Optn R...or D.
So, I ended up getting a new HD and a copy of the original OS (10.5.6 Leopard). I first booted up from the Install DVD that came in the mail... that worked. I entered DU and cleaned the HD and ran the repairs... it all came out saying "The volume appears to be ok." I did the repair a few times for good measure.
Then I attempted to install.... I get the message "OS X can not be installed on this computer." I am baffled at this point. I reboot... booting from the disc again... same message.
Then I switch the HD for the new one... I ensure that it is GUID / Mac OSX extended Journaled... and attempt the install... I get the same "...can not install..." message.
I call Apple, they suggested that I get SnowLeopard (10.6.3)...so I do that. It won't even recognize that as a bootable drive. I get the "?Folder" at startup after the disc spins for about 1-2 minutes.
They sent me 3 discs after I called again. This time a "Not For Resale" version of the install DVD and another copy of 10.6.3... and a CD version of 10.6.1 update. I feel that if they sent me a CD version of the install disc... or the recovery disc it would recognize them. Still I find it strange that the 10.5.6 discs are DVD and it recognizes them...
Admittedly I bought the Leopard discs from a retail store that is not Apple... Apple doesn't carry Leopard...and I wanted to see if I could even get the base OS back on the machine... no luck so far. I'm hoping that the discs were not serialized to the machines that they might have come with... I would be highly upset.
So... my question (finally) What is the problem here?
- Why am I getting this message "OS X can not be installed on this computer"
- Even when holding down the C key...it's not recognizing 10.6 discs... but it does recognize 10.5..
Short of replacing the logic board here... what do I do? I've been through it all with this machine.
Puan 0
2 Yorum:
To fix the aforementioned “unspecified error”, follow the steps below:
First click “OK” on the error window.
Then click on “Utilities”on the top of the computer, then “Terminal”.
Once opened type in terminal the word “date” without the quotes and hit enter. This will give you the computer’s current time and date.
To fix the date, type in the current date/time in the following format: “date mmddHHMMyyyy”. (mm = two digit month, dd = two digit day, HH = 24 hour, MM = minute, yyyy = 4 digit year) So if it is currently 10:46am, June 19, 2015 the command would look like: “date 061910462015”.
Once you have the current date/time inserted, you will then hit enter. You can double check to see if it was set properly by using the “date” command once more, it should show the date/time you have just typed in (see image below).
All information grabbed from this site: https://blog.macsales.com/31640-tech-tip...
tarafından
In the times this has happened to me it has been a failure to updated the Date in terminal, the computer thinks its too old to install a new OS than it originally shipped with.
To do this go to Utilities> Terminal > date 0321013018 (type in month day time year) this example is for the date March 21, 2018 at 1:30pm
When I update the date/time it installs smoothly!
tarafından
Yorum Ekle
I get the same crud. I enter accordingly with my date time like the example and get this.
date: bind: Permission denied
date: settimeof day (timeval): Operation not permitted.
I’m running 10.6.8 and trying to upgrade to Yosimite 10.10. Tried both an operation DVD and a download off the internet. Anyone know a solution. Thanks.
Puan 0
2 Yorum:
Apple are heartless. I'm sure it's some coding some evil programmer put in the updates.;
tarafından
Anyone found a fix on this?
tarafından
Yorum Ekle
Yanıtını ekle
Mark Wynn sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 32
Her zaman: 51,413
