Ana içeriğe geç
Battery or Dock Connection!
I have an older itouch first gen, when I charge it it doesn't hold the charge, can you tell me if this is more likely a battery or dock connection issue? It does take extra effort to show when it is connected to charge... seems looser than in the past
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Being a first generation it is likely a battery. You can visually inspect the dock connector to see if any pins are missing, bent, or a buildup of debris. However, if the dock was faulty you may get no response when plugging the device in. The batteries are not made to last forever (planned failure).
This repair requires solder, but is the easiest of the touch batteries to install.
Good luck!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
matt119 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 379
