Ana içeriğe geç
The first generation of the Chevrolet Equinox, a crossover SUV from Chevrolet based on General Motors' Theta platform.
When I start my car, it hesistates to turn over?
For the past 6 months, every once in awhile the vehicle does not want to start and hesitates to turn over. It is to new for the starter to be going out. Any suggestions?
Update
The car is a 2005, it has 113,000 miles on it. I just replaced the battery last year.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum
Melany, there could be plenty of reasons for it. What exact year is it? How old is the battery? How many miles are on it? It could be from corrosion on the battery post, to starter, to starter relay to ECM, so we need to narrow it down a bit....
tarafından
Melany, does it turn slowly and then it goes faster when you start? Turn your lights on and see if they go dim when you start it? My gut feeling says it's the starter that is failing.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
There is a TSB (technical service bulletin) for this problem.
Bulletin No.: 02-06-04-015A
Date: March 07, 2006
TECHNICAL
Subject:
Intermittent No Crank, No Start (Clean Battery Side Terminal Stripped Threads, Replace Battery Cable Bolt)
Models:
2001-2007 GM Passenger Cars and Light-Duty Trucks (Including Saturn)
2003-2007 HUMMER H2
2006-2007 HUMMER H3
2005-2007 Saab 9-7X
with Side-Mounted Battery Terminals
Supercede:
This bulletin is being revised to update the models and provide a new labor operation number for this repair. Please discard Corporate Bulletin Numbers 02-06-04-015 and 03-06-03-006A (Section 06 - Engine/Propulsion System).
Condition
Some customers may comment on an intermittent no crank, no start condition.
Cause
This condition may be due to poor battery cable connections. Cross-threaded/stripped battery cable bolts inside the battery side post terminals may cause poor battery cable connections.
Correction
To avoid replacing the battery , do the following steps:
^ Clean the threads in the battery side post terminals using a 3/8" (# 16) NC bottom tap.
^ Replace the battery cable bolt.
The battery cable bolt is serviced separately from the cable and is available from your Parts Department. Be sure to use the correct bolt.
  • If the battery is new and this is not the problem it's likely a fuel pump issue. Try turning the ignition on for a few seconds before starting it, this would allow the pump to re-prime the fuel system.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
+ very nice answer
tarafından
Yorum Ekle
Typically when a vehicle has a slow starter, it's an indication of a dieing battery. If you're battery is old or "abused" (maybe you listen to the radio a lot with the car off?), it can begin to lose it's voltage, especially under load. If you have a multi-meter, test the voltage of your battery when the car is completely off, when the car is starting, when the car is running and when the car is revved up to mid-low RPM. Reading these voltages can tell you A LOT about the state of your battery and your charging system. if your battery is below 12 V when the car is off the battery is dead. If the battery voltage drops super low during starting it can also indicate a dieing battery. Try it out and let us know the results!
Puan 1
Yorum Ekle
Car want come on at all it hestated to start yestet day car has been siting havent drove al most a month i have equinax 2005
Puan 0
Yorum Ekle
Yanıtını ekle
Melany sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 10,526
