Ana içeriğe geç
Lenovo 100e Chromebook 2nd Gen, hafif ve kolay erişilebilir bir dizüstü bilgisayardır. Kasım 2019'da piyasaya sürülmüştür, model numarası 81QB000AUS'tur.
How to reset managed chromebook to normal settings
I recently bought a chromebook of this brand off Craigslist, and it had a dead battery. I put in a new one, and see that it is managed. I tried another solution, and it didn't work. So, any suggestions on how to reset?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
You can't reset a Chromebook without the login information needed to access it. You may, however, try to perform a clean installation of the Chrome OS.
To perform a clean install, first create a bootable USB with the Chromebook Recovery Utility found at https://chrome.google.com/webstore/detai...
Then, use the bootable USB to wipe the Chromebook clean and reinstall Chrome OS. Put your Chromebook into Recovery Mode by pressing and holding Esc + Refresh, then press the Power button. A prompt will appear that will ask you to insert the bootable USB drive. Insert the drive and follow the prompts to reinstall Chrome OS.
You may then be able to configure the device with your own username and password.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
If you have factory reset the chrome book and it asks you to re-enroll the device, your only option is to contact the seller unfortunately.
Most companies will have the option set that they have tk be re-enrolled to their domain, you know incase someone steals it and sells it on Craigslist ?
Puan 2
Yorum Ekle
Yanıtını ekle
Roger Ratzlaff sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 35
Her zaman: 6,415
