Ana içeriğe geç
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
131 Soru Tümünü görüntüle
After removing the screen, how to replace the headphone jack?
I need to replace the headphone jack on my 12.9” 1st gen iPad pro. I found that ifixit has the tools and replacement parts, but I can’t find a guide to do it. Is there another device that has a similar guide so I can piece together what I need to do? Is it as simple as replacing the component after the display has been removed? Any guidance would be useful. Thanks!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hey,
The headphone jack is on the top left corner of the iPad and you need to remove 3 screws to remove the jack and then all you need is a replacement jack to fix it back up! To remove the connector side of thing first you need to remove the EMI Shielding as mentioned in the iFixit guide in step 10 and then you need to disconnect the headphone jack cable! Take a look at step 11 in the iFixit guide as it will help you in locating the headphone jack connector :D
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thank you very much!
tarafından
You're welcome :D, Glad I could help!
tarafından
Yorum Ekle
Yanıtını ekle
Kevin Roe sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 12
Her zaman: 38
