Ana içeriğe geç
Repair information and guides for the updated version of the 2015 Retina MacBook that was released in early 2016. Model A1534 / EMC 2991
140 Soru Tümünü görüntüle
Laptop will not turn back on after replacing display assembly
I replaced the display assembly of my MacBook Retina Early 2016 over 24 hours ago now, and the laptop will not power on through either tapping or holding the power button. I have tried holding Shift, Option and Control keys, as well as resetting the PRAM, too, to no avail. It’s definitely not just a display issue, as the light on the Caps Lock key is not illuminating, and the track pad is not clicking. Anything else I can try?
edit: sorry, I should’ve clarified - I definitely disconnected the battery using the pushbutton before disconnecting anything, and I have had a regular ol’ USB charger charging the laptop for ~24 hours now
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
For retina Macbook, if you disconnected the battery using the disconnect pushbutton, you have to use a regular USB charger to charge it back on, pressing the power button along probably won’t work.
If you didn’t press the pushbutton before disconnecting the trackpad, you probably have fried something.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
sorry, I should’ve clarified - I definitely disconnected the battery using the push button before disconnecting anything, and I have had a regular ol’ USB charger charging the laptop for ~24 hours now
tarafından
@hannahg then try swapping the old screen back, see if it is going to power on, if something broke, troubleshooting remotely without even able to see anything is going to be difficult.
tarafından
Yorum Ekle
Yanıtını ekle
Hannah Glober sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 39
