Ana içeriğe geç
4 Kasım 2017'de satışa sunulmuştur. Model A1865, A1901. GSM ya da CDMA olarak 64 ya da 256 GB kapasitelerinde, Gümüş ya da Uzay Grisi renklerinde satılır. ("iPhone 10" olarak da telaffuz edilir.)
1199 Soru Tümünü görüntüle
Rear camera is blurry after housing
I replaced the housing on a customers iPhone x
1x is not focusing, 2x works fine, flash works
It was working fine before
I cleaned the camera lens and the glass, 3x the focus problem persists. I've ordered a camera replacement to see if that'll work. Will this affect face ID?
Also what may of caused the focus problem?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
The FaceID is located within the front camera/speaker assembly so shouldn’t be affected by rear camera replacement. As for the camera itself, unfortunately, it does seem to maybe have sustained some damage during the repair to the autofocus module, although I’d suggest completely wiping the device to ensure no software issue is causing this (if the device belongs to a customer and you aren’t able to do this, try moving the camera into another compatible device that can be reset and tested), and if the problem persists after this, replace the rear camera entirely.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Che Hayden sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 167
