Ana içeriğe geç
A more affordable, purely handheld version of the Nintendo Switch game console, with integrated Joy-Con controllers and a slightly smaller screen. Released September 20, 2019.
175 Soru Tümünü görüntüle
Switch Lite Wont Turn On
A good few times now after being put on charge overnight the console will not power on. I’ve tried resetting by pressing the power button for 12 seconds etc to no avail. All times before now the console has come back on by itself after being left on charge for further time. There has been good amounts of time between this happening so despite happening a total of four times now the console functioned perfectly fine for the months in between. No charge issues, battery seems fine etc.
This time however the console hasn’t come back on and its been a couple days now. No damage, water or physical as happened. Anyone have any idea why this has happened all these times and why possibly the console hasn’t come back on this time around?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi Jamie!
Could be a lot of things. Motherboard fried, charger which is faulty, faulty battery or something else. I think it’s motherboard related as you describe it. I advise to test with another original charger first. Do you still have warranty on this device? Otherwise I would return it.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
I have tested with multiple official chargers already to no joy. I don't think it's a battery problem as the console has worked fine in between stints. Unfortunatly the console is no longer under warranty and I've already had it fixed once by Nintendo (broken charge port). Going to send it off to Nintendo hopefully the don't charge me an arm and a leg again as the issue has not been caused by damage etc.
tarafından
Hi Jamie! The motherboards are very expensive and hard to find. Let's see what Nintendo has to say, I think you do good by contacting Nintendo for this issue.
tarafından
I was plugging & playing on my Oled. @ 87% stopped charging altogether & will not charge.. Green light flashes off & on the dock. Turns off & on np. Never had this happen before:( pls help
tarafından
Yorum Ekle
Plug the console in and hold down the volume buttons. The + and - together it will go to factory reset.
If it does not..
Well it's not the problem I thought it was.
Puan 0
Yorum Ekle
Yanıtını ekle
Jamie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 17
Her zaman: 1,029
