Ana içeriğe geç
GMC Sierra dahil olmak üzere General Motors tarafından GMC markası altında satılan C/K kamyonetler için onarım rehberleri ve destek.
Rear running lights do not work?
The rear running lights do not work on my 94 GMC Sierra . My turn signals and hazards are fine. and brake lights work when I hit pedal , but my tail lights that stay lit while driving do not work and I have changed the bulbs already and no fuse is blown. Any suggestions?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
If fuses and bulbs are fine then check the switch. Make sure that it is supplying the running lights with power when selected. If not, and you've got power coming into the switch, then you need a new one. If it IS sending power to the lights, then you'll need to trace the wires back and make sure they aren't broken. If the power wires aren't broken and you're getting power to the lights, then you'll need to chase down the ground.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Wait so I have no tail lights or running lights and I have power coming into the switch but not out to the lights. And I just tried replacing the switch what next?
tarafından
@kaidadehaven so you had power TO the switch but not FROM the switch? You replaced the switch and still nothing? Verify power is coming from the new switch first. Then see if there's power at the lights. Could be a broken ground or broken power wire.
tarafından
Yorum Ekle
Yanıtını ekle
Von sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 29
Her zaman: 3,892
