will not power off
My tablet will not shut down. It ks frozen trying to shut down. Is thdre a reset somewhere.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
You did not tell us which tablet you have ;-) but try this from here :
"To reset your Xoom when the screen is totally unresponsive, press the power and volume up buttons at the same time for about three seconds. The two buttons are right next to each other on the back and side of your Xoom. This is a soft reset. It's the equivalent of yanking the batteries or totally powering the device off."
Bu yanıt yardımcı oldu mu?
This also worked for the tablet not powering up. It fixed problem not turning on. Thank you
you are welcome...:-)
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 2,962
3 Yorum
How about a hard reset without having to use the settings menu? My xoom is somewhat responsive seldom but more often than not it now won't do anything except restart using a soft reset but when it restarts it becomes unresponsive within seconds or well under a minute. can I do a hard reset without using the settings menu?
Jeremy Hite tarafından
I was erasing emails I had Uninstall a mahjong game the clean master came on where it was. Checking for residual file. Can't get off screen can't turn off or clear. Been stuck on for over a hour when battery runs out will it be okay. My tablet is motorola xzoom with Google
Tina L Brannon tarafından
My tab freezed for some time so i turned ot off and when i tried to turn it on it didnt work
Naumana Rehman tarafından
