Ana içeriğe geç
Repair guides and support for riding lawn tractors sold under the Murray brand name, currently owned by Briggs & Stratton.
139 Soru Tümünü görüntüle
Year of Murray tractor
I have a Murray FLT 75 and am stumped on the year of it would appreciate any help finding the year of it. My model number is # 7800370 and my serial number is # 2012838095. Hopefully someone can figure it out.
Bu iyi bir soru mu?
Puan 0
2 Yorum
Pre 1980ish it was a 4 year date code with the first digit representing the year then the last three the day of the year. Ex 9150 is 1979. From late 1980 and 1990 and just before 2001 I think they swapped it. Still 4 digit but the last number is the year. 3550 like mine reads should be 2000 on day 355. Don't take this as gospel.
tarafından
I’m looking to see what belt size I buy for a 2018 Murray175-42 riding lawnmower mower. What’s the difference between a deck belt and lawnmower belt? Serial 13an7755058 model 1L048B30252
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Step 1
Look for the data tag on the Murray lawn mower. These tags are found in the rear of the mower or under the seat of riding lawn mowers, or in the center of the deck of push mowers.
Step 2
Identify the four digits after "Date Code."
Step 3
Interpret the four digits to figure out the year of the Murray mower. The year the mower was manufactured is represented as the first digit, and the day of the year it was produced is represented by the last three digits. For example, if the date code is "4156," the mower was produced in 2004, on the 156th day of the year. The date code could also indicate 1994. If you are unsure if your mower is that old, go to the next step.
Step 4
Find the model number located on the data tag. Pre-2001 Murray mowers have five-digit model numbers followed by a dash and a single-digit number. Post-2001 models have a five- or six-digit model number with no dash. If the model number has a dash, the date code, for example, will indicate 1994 rather than 2004.
Bu yanıt yardımcı oldu mu?
Puan 2
6 Yorum:
I found it quite confusing figuring out the year of this lawn tractor your information was very helpful thank you once again.
tarafından
I have a murray. Model number: 42813X92B Date Code: 0534. So based on this statement, the mower was created on the 534th day of either 2000 or 1990. Doesn't seem to work out right.
tarafından
@Gregory Malsack I can only tell you what I know or have found out through research. Yours makes no sense to me either. Try contacting Murray with serial number and they'll be able to give you a better answer.
tarafından
Hello I have a murray 42614A date code 3462 what year is it please help? It is a 14hp briggs and stratton twin 42 inch deck
tarafından
Well I have a question mine has a top number and a bottom number the top number is 42614x92a and the number below it is 1233
tarafından
1 tane daha yorum göster
Yorum Ekle
Didnt quite understand also.
My Murray is:
Model number: 38608X20B
Date of manufacture: 1070
What year is it?
Puan 0
1 Yorum:
Either a 2001 or a 2011, I'd say. Best answer I can give. Might be able to contact Murray with serial number for a better answer.
tarafından
Yorum Ekle
Yanıtını ekle
Alvin Slovinsky sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 36
Son 30 gün: 168
Her zaman: 4,902
