Ana içeriğe geç
The M1 chip in the Mac mini is Apple's first System on a Chip for Mac, integrating GPU, CPU, RAM, and other components for improved performance and efficiency. The M1 in the Mac mini has an 8-core CPU with four high-efficiency cores and four high-performance cores along with an integrated GPU that has 8 cores.
14 Soru Tümünü görüntüle
How to clean dust from 2020+ Mac Mini case?
Based on the new ‘not-accessible’ for upgrades/replacements design that has become common for Apple designs, how does one check and if needed, remove dust from the cabinet and cooling fan for proper maintenance? (The bottom plate obviously CAN be removed… but not as easily as the 2012 and 2014 models!) Any help would be appreciated!
Thanks
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
This model’s reparability issue comes from lack of parts and soldered board components, cleaning on the other hand is trivially easy, 10 minutes max and you are already at the bottom of it.
Also I don’t see any possibilities of this thing dusting up and blocking cooling anytime soon.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Frederick Rich sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 9
Son 30 gün: 25
Her zaman: 1,267
