Ana içeriğe geç
The Galaxy Watch Active2 is a smartwatch from Samsung Electronics. Its model number is SM-R825, SM-R830, or SM-R835 and was released in August 2019. Repair your Samsung Galaxy Watch Active2 with these guides.
stuck on rebooting screen not turning on
rebooting screen loop keeps appearing and then disappears without turn on
Bu iyi bir soru mu?
Puan 5
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Unscrew the 4 screws and remove the back cover. Disconnect the battery and leave for a few minutes. Reconnect the battery and try turning the watch on.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Where did you get the screwdriver from? - it looks like a tiny 3-cornered star.
tarafından
Yorum Ekle
En Yararlı Yanıt
seems like you have a hardware issue. its probably under warranty still so contact samsung and see what they have to say bout it. hope this can help can help!
Puan 1
6 Yorum:
no Samsung store said it can't be fixed
and after that, I searched online and found out that many people had the same issue with no fix from Samsung or replacement
also people had this issue fixed with active one but same way not working on active 2
tarafından
I had the same issue a few days ago, but it happened at the same time that the battery stopped holding a charge. Going to replace the battery with one from Amazon and see if that resolves the issue...
tarafından
So replacing the battery did resolve the rebooting issue, but I broke the ribbon cable connecting the power button to the motherboard in the process so the watch is now inoperable.
tarafından
I'm getting the same issue after the update just came through. Started seeing error yesterday night. I'll try replacing the battery myself too.
tarafından
my watch keeps showing the logo over and over not coming on and if i press the buttons it will show the rebooting screen and then do the same thing over and over again
tarafından
1 tane daha yorum göster
Yorum Ekle
I am having the same problem with my galaxy active 2. I was wearing it while teaching and it had a 89% charge on the battery and it just all of the sudden started into the reboot loop. I've tried resetting it and it didn't work because I have no connection with my phone. So it's best to try to replace the battery then?
Puan 0
1 Yorum:
Possibly, though there's also a way to enter recovery mode that you might try in order to reset it before disassembling the watch. The battery replacement was relatively easy and the battery kit came with instructions, the hardest part was unsticking the old battery from the frame. I dropped the internals when putting it back together which broke the power button cable, as far as I can tell there's no way to fix that. So be careful not to drop it!
tarafından
Yorum Ekle
Leave the watch to go completely flat leave it for a couple of weeks trechargeLeave the watch to go completely flat leave it for a couple of weeks trecharge
Puan 0
1 Yorum:
Im sorry I didnt quite understand what you said
tarafından
Yorum Ekle
Yanıtını ekle
Maha Mansoor sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 31
Her zaman: 19,488
