My 3ds does not turn on from battery. I found a short circuit.
My 3ds does not turn on from battery. I found a short circuit as in the picture below:
These are the things I tested:
- Insert battery: turn it on —> nothing happen (no light)
- Remove battery, plug in charger: when plug in charger, charging led (yellow led) turns on for about 5 seconds then off. Turn on the device —> nothing happen (no light)
- Insert battery, plug in charger: when plug in charger, charging led (yellow led) turns on for about 5 seconds then off. Turn on the device —> device turns on and works as normal.
These are the things I found:
- Battery fuse was broken
- There is a short circuit as in the above picture
Please help me to fix it. Thank you!
Bu iyi bir soru mu?
