Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3530 Soru Tümünü görüntüle
Why does my iPhone constantly vibrate when plugged in? No display.
So this was a phone given to me by a friend. The power button didn’t appear to work so I suggested a replacement. It did this wierd thing where it would only hold a charge to 2% when plugged in and switch itself off. So I replaced the volume flex and now there is no disaplay but when it is plugged into power, it just vibrates. It started as a contiuous vibration, but now it’s more like a phone call - intermittent. I had thought about changing the battery to address the charging issue, but I can’t seem to get my head around the vibrating situation. Any info would be helpful, thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
This is a hated issue where if the battery gets over a certain % it kills itself. It can either be the battery, software, charger or blown cap or resistor. Try turning off battery percentage and turn it back on, try different software and finally change chargers. If all else fails take it to a repair shop as this can be a tricky subject
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Brandon Frost sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 44
