Ana içeriğe geç
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
Closed lid sensor not working well
When I close the lid on my macbook1,1 the system does not go to sleep unless I use squeeze the left edge of the laptop. in other words, I need to use moderate pressure to squeeze the lid closer to the keyboard before it will go to sleep.
I presume there is some type of sensor installed in the lid and base. Is this true? If it is true, can I make it more reliable via an adjustment, or is there a part that needs replacement?
Thanks,
Mitch
Bu iyi bir soru mu?
Puan 1
3 Yorum
There is no misalignment between the lid and base when closed. When closed, the front edge of the display does touch first and thus at the location of the magnet there is a small gap about the thickness of one or two business cards. this is the area where I "squeeze" to get the macbook to sleep.
So if it's not an alignment problem, is it possible that either the magnet or sensor has moved or is malfunctioning?
Do you know if the sensor or the magnet is replaceable or is it part of a bigger, more expensive assembly?
I wonder if I just tape a small magnet to that area to keep the Mac asleep. My intention is to just use the MacBook in clamshell mode.
Thanks very much for your help,
Mitch
tarafından
You could try to remove de display bezel and check if the magnet is correctly installed. If so then the battery charging board may need to be replaced.
tarafından
My older MacBook a1211 Pro started to shutdown and resume erratically. I ended up removing the lid sensor by disconnecting it from the flat cable under the keyboard. There are 3 connectors, the lid sensor is in the middle.
Just disconnect it. Thank God, it worked !.
I hope many Mac users will benefit from this procedure
Best Regards
Emmanuel Crepsac
ecrepsac@gmail.com
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi Mitch, welcome to iFixit Answers.
A magnet located a the left edge of the display enters in contact with a sensor located on the battery charging board (under the top case) when you close the display, this action triggers the machine sleep function. If your display is a little twisted there could be a gap between the two components causing a bad contact and the macbook sleep issue. Check if your display is closing firmly to the top case. There could be a hinge problem. Was the macbook dropped ?
Bu yanıt yardımcı oldu mu?
Puan 6
Yorum Ekle
Yanıtını ekle
Mitch sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 2,322
