Ana içeriğe geç
Released on November 22, 2005, the Xbox 360 wireless controller is the primary game controller for the Microsoft's Xbox 360 home video game console.
Unable to remove logic board after opening shell. Just pull harder?
Thanks for the guide! However once I have separated the shells, the logic board still seems attached. Not sure if I just need to be pulling harder, but it definitely feels like there is another post I can’t see?
If it’s relevant, this is specifically the Halo Reach Ltd Edition version of the controller.
Edit: Attached a photo:
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
looks like youve got all the screws removed.
try lifting gently around the headphone charging port and see if its caught on anything.
did u spill anything on it before? maybe something sticky? in which case yes youll need to pull harder. its very odd that it wont separate. just take it slow and be sure to look and see where its “tighter” than other places. so like lift one side of the PCB and see if theres any play in the board. that might give you a clue as to where its getting caught.
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
Thanks! Nothing spilled on it, but it seems like the central plastic post was a bit expanded and was holding onto the logic board tightly. Used a lever just under the board near the center post and it popped off easily enough.
Sorry about the waste of time, but maybe it will be helpful for anyone else struggling with it
tarafından
@shaundave if you learned something it wasnt a waste of time, also someone else might find this and save them the hassle also! glad you got it removed!~
tarafından
cant understand solution, plz help.
tarafından
Yorum Ekle
going thru the same problem but i cant understand the solution, please explain,
Puan 0
Yorum Ekle
Yanıtını ekle
ShaunDave sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 414
