Ana içeriğe geç
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 Soru Tümünü görüntüle
If I upgrade to SSD, that allow me to go to macOS Mojave or higher?
I’m planning to upgrade the HDD to SSD. Which SSD is recommended and what tools do I need?
Will the new SSD allow me to upgrade to new OS since my current OS is High Siera? I like to upgrade to macOS Mojave and the up coming Monterey?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Metter Chin upgrading your SSD won’t alter the limits of the systems CPU and firmware. While I do think you’ll gain performance adding a SSD it won’t technically allow you to upgrade to a higher macOS your system is limited too.
With that said there is an OS hack which will over-ride Apples limiter. But there won’t be much benefit as the features you are likely looking for won’t work in your system as the hardware that’s needed is missing. DOSDude Jumping up one OS release higher can make sense if your applications require it. Jumping two or more from that your system was limited to becomes more iffy!
Here’s the guides you’ll need to follow:
Swapping out your HDD for a SSD while easier offers less benefit than adding the SSD which is a bit more work. In either case any 2.5” SSD will work.
I think you’ll find this kit will get you everything you’ll need iMac Intel 21.5" and 27" (Mid 2011) SSD Upgrade Kit to replace your HDD.
If you go with the dual drive setup then you’ll need iMac Intel 27" (Mid 2011) Dual Hard Drive Kit and the SSD Crucial MX500 500 GB SSD or Crucial MX500 1 TB SSD
Crucial MX500 1 TB SSD Görseli
Ürün
$62.99
Crucial MX500 500 GB SSD Görseli
Ürün
$41.99
iMac Intel 27" (Mid 2011) Dual Hard Drive Kit Görseli
Ürün
$27.99
iMac Intel 21.5" and 27" (Mid 2011) SSD Upgrade Kit Görseli
Ürün
$100.99
iMac Intel 27" EMC 2429 Hard Drive Görseli
Kılavuz
iMac Intel 27" EMC 2429 Hard Drive Replacement
Zorluk:
Orta
20 - 30 minutes
iMac Intel 27" EMC 2429 Dual Drive Kit Görseli
Kılavuz
Installing iMac Intel 27" EMC 2429 Dual Drive Kit (HDD or SSD)
Zorluk:
Zor
1 - 3 hours
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Samsung 2TB 870 QVO SSD ans you get cloning software free of charge from Samsung. As for tools a mixed screwdriver set.
Puan 0
2 Yorum:
Thank you Peter. Will this allow the Mac OS upgrade with this computer?
tarafından
Peter - I love the Samsung drives but there's a bit more that swapping out a drive. This series requires a thermal sensor be added if you replace the HDD. In addition Metter Chin's question was more on if going with a SSD would allow him to upgrade to a higher macOS version. Swapping out the drive alone won't change things from that perspective.
Apples OS installers don't allow one to run OSs which are not suitable for the system as the OS's tend to include enhancements for newer systems hardware which clearly is not present in an older system. While there is a hack one can install onto ones system to allow you to go with a higher OS version than what Apple intended, it won't allow you to gain that much benefit and in some cases can make your system unstable. I don't recommend doing it on your main system. It can be useful to test things out on a second backup system though.
tarafından
Yorum Ekle
Yanıtını ekle
Metter Chin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 100
