Ana içeriğe geç
Samsung galaxy a21s, please help! Black screen after dropping it.
So i dropped my phone. And its broken, when i turn it on it just make a small signal and turns off. I want to repair the phone by myself. Do i need to change the whole display or can i just change the screen? Or do i need to repair it another way?
Bu iyi bir soru mu?
Puan 15
2 Yorum
Ok, Will that Repair the Phone? There is a tiny flash of light happening for a mirco second When i Power the Phone on.
tarafından
اريد إسترجاع ألوان الهاتف
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
@sebbialsvik going by your description I advise that you change the complete display assembly. Easiest of all the other options even so it is not an easy task in general. This Video should help you with the task https://www.youtube.com/watch?v=qj8zk57D...
Bu yanıt yardımcı oldu mu?
Puan 6
5 Yorum:
Ok, vil det reparere telefonen? Det er en liten lysglimt som skjer for et mirco sekund når jeg slår på telefonen
tarafından
I am certain that it would. The flash of light is probably just the screen getting electrically excited but is to broken to turn on.
tarafından
Ok, thank U so much, i Will update you When i have replaced the screen
tarafından
>The flash of light is probably just the screen getting electrically excited but is to broken to turn on.< No actually that happens to me everytime i try to turn off my phone after a poweroff it usually happens 3-4 times and then it fixes itself
tarafından
تم تبديل الشاشة ومازالة المشكله عند محاوله تشغيل يظهر علامه وضع آمن ومباشره يتم ايقاف تشغيل ولا اجد حل للمشكله
tarafından
Yorum Ekle
En Yararlı Yanıt
This is a common issue with the A21S, if you can see an image for a split second or it’s flashing on and off, disassemble the phone from the rear using hot air or fan, take the backplate off, remove the battery and remove the LCD flex cable, reconnect the flex cable back and then the battery, if the screen is not damaged it should work fine. This happens because the LCD flex cable gets slightly disconnected from the FPC connector.
Puan 14
1 Yorum:
This goes into great detail on how to fix this but heres the thing, everytime I try to turn on my phone for lets say if the battery died or something the power button on my A21S, its a gray screen for a split second and then it turns off this happens for 3-4 times and then i can normally turn it on again.
tarafından
Yorum Ekle
Yanıtını ekle
Sebbi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 44
Her zaman: 5,247
