How do I add ram and how much ram can I add?
want to speed up my imac g3 m5521 and how well will it operate if maxxed out?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hello James Just in case your computer has the door on the bottom I am including a link to an article on upgrading early imacs. Scan down to the bottom of the article and you will see a series of pictures. Click on them one at a time and they will expand giving you a clear idea of what to do. Hope this helps you.
http://www.macworld.com/article/2496/200...
Link to a guide showing how much memory Macs can use.
http://www.everymac.com/systems/by_capab...
Maxed out it will run better but not as well as a new iMac.
Bu yanıt yardımcı oldu mu?
Maximum RAM: 1.0 GB (2*512MB)
Type of RAM Slots : 2 - PC-100 3.3V 168-pin SDRAM
This is for a M4984 -- not a M5521 and may not be accurate for his computer.
The M4984 has a max ram of 384 MB--the M5521 has a max of 1 GB.
yes I know, but I though that it was almost similar as the change in these iMacs were only hardware updates.
James follow rj link
- "almost similar", just doesn't cut it with computers
Imac model M5521. Can I install a wireless connection, this has only dialup capability? Same question re DVD drive, can one be installed? Is there a source for these items?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 5,454
