Ana içeriğe geç
21 Eylül 2018'de piyasaya sürüldü. A1920, A2097, A2098, A2100 modelleri. GSM veya CDMA / eSIM veya nano-SIM / 64, 256 veya 512 GB / Gümüş, Altın veya Uzay Grisi seçenekleriyle mevcuttur. ("iPhone 10 S" olarak telaffuz edilir.)
What is the TG0B sensor?
Does anybody know what the TG0B sensor is and what could cause thermalmonitord returning “not alive” with context SD: 0 BC: 1 Missing sensor(s): TG0B
When that happens, the shown battery filling level drops to 0% and shortly after it will reboot with the mentioned error in the panic logs.
First I suspected that the error might be related to the lightning port. But replacing it didn’t fix it.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
4 Yorum
hi if you solve this problem please tell me what you replacing!
tarafından
Hello , I am facing the same problem with my iphone . If you have solve this problem ,can you tell me by replacing what you solve this problem?
tarafından
@mehrajsalfi Start by following @oldturkey03's advice and replace the battery. As he said, sensor TG0B is located on the battery, so that's the place to start.
The sensor is read by two signals that pass through the battery connector and through a couple of components mounted next to the connector. Occasionally a component will get knocked off the board in the process of connecting and disconnecting the battery, which can cause that same error.
tarafından
Dan betul ternyata fleksibel sensor kamera depan sobek
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@mfmayer start by replacing the battery. If you already have done this, check the components around the battery connector. Make sure you did not pop one off. Those can be causes for this as well. Ultimately “SD: 0 Missing sensor (s): TG0B” - battery / TIGRIS; result is that the device does not see the battery.
Bu yanıt yardımcı oldu mu?
Puan 6
Yorum Ekle
Yanıtını ekle
Matthias sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 26
Son 30 gün: 94
Her zaman: 15,689
