Ana içeriğe geç
The Fitbit Charge 4 is a fitness tracker released in March 2020. It's new features include Active Minutes tracking, Spotify controls and Fitbit Pay.
Tiny broken screws, Fitbit Charge 4 band holder
Hi all,
The band holder broke off my Fitbit Charge 4, along with more than 50% of each screw. Any advice on getting the rest of the screws out? The sleeves around the screws have little nibs on them that prevent them from spinning freely (I tried to squeeze them with pliers but wound up with little nubs I can no longer grab onto). Please see the intact side and the broken side in the attached pictures.
Any advice would be greatly appreciated!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 11
Yorum Ekle
9 Cevap
Filtre ölçütü:
Just ran in to this too. The only solution would be a replacement housing which people do sell, but at a price that is more than the whole body alone is worth.
As much as I dislike Amazon, they have a few listings of a whole watch band/face that the Charge 4 can slide in to the back of thus eliminating the need for the Fitbit’s fragile band attachments. These work a treat.
EDIT: Since I ended up deleting the "permanent" link in my comment below, what I'm talking about looks like:
Bu yanıt yardımcı oldu mu?
Puan 2
7 Yorum:
can you tell us the exact name or post a link to what you are talking about, please. thanks!
tarafından
Sorry for the delay in responding. Something like this: https://www.amazon.com/GOSETH-Compatible...
Disclaimer: I have no connection to that particular seller or link. I gain absolutely nothing if you click and purchase that specific item. There are a few similar options, see which you like best.
tarafından
In case that link disappears in a few months time, here's an image that shouldn't go away: https://i.imgur.com/e1dOLcl.png
Searching for something like: "fitbit charge 4 aftermarket band" should get you there.
tarafından
@soondog (Last comment just so you get a notification of reply. Sorry for the spam ya'll)
tarafından
did anyone tried this band from amazon ? and is it effective or should i use glue or something like that ?
tarafından
2 tane daha yorum göster
Yorum Ekle
En Yararlı Yanıt
After checking u tube and the Fitbit website, I found no solutions or any great answer to repairing the broken screws on my Fitbit charge 4 band holder. Was ready to give up and thought I would have to break down and buy a new Fitbit but discovered the Charge 5 even had cases of the same problem and no info on Versa plus the extra cost. So took the broken screws out and cleaned the connections surfaces for the band to the watch body and used gorilla super glue, and rubber bands to hold it in place. I had lost the small spring which holds the 2 tabs up which lock the band holder to the watch so cut a very small piece of rubber band to put in its place. After a 24 hour set up everything seemed strong, the button release no longer works, but have been wearing the watch constantly for the last 2 weeks, doing a lot of mechanical and labor intensive work, and the band is secure!!
Puan 2
2 Yorum:
Thanks for your comment... I also did lost the little spring, that is preventing me to glue the 2 little pieces, was thinking on making it stale like you did but did not know really how, the only problem of not being able to release the band from that one is that bands tend to fail quite often but I guess that will be the next issue. I can tell that I started with Fitbit with a Flex 2 and an Alta HR, those 2 still work, just issues with the charging cables and bands. Then I moved to Charge 3 and Charge 4, those had strap band issues, and now the Charge 4 had the band holder issue and I found out this is common. On the Charge 3s I suffered the dimmed screen and also one of them now does not turn on the screen... I got a Charge 5 for my wife like a year ago, no issues so far, just the lack of floor count, but I am done with Fitbit. I am going to move to Xiaomi Mi band, more cheaper and I guess better case / strap design. :-)
tarafından
Same problem here, we tried to glue it with superglue, it held for a few months then broke again.
tarafından
Yorum Ekle
My partner and I have both had these fail on us now, luckily the most recent one to fail might still be under warranty.
Gluing the last one had limited results, only lasted a couple of days before falling apart again.
In my opinion it's a pretty poor design, looking at the tiny little plastic poles that have to cope with the strain of the watch band.
Interesting to hear that the Charge 5 has the same issue, I think we'll be changing to non-Fitbit branded fitness trackers sooner or later.
Puan 1
Yorum Ekle
@domper i had the same issue, exact same failure. Both screws just "sheared" off at the same time, same place.
Ended up just soaking the thing in superglue. Screen still works even with 50% covered in glue lol.
Has worked for over a week now, and if it breaks again I'll just use more glue.
Fitbit makes fragile products so i will just not buy one ever again and get something else if this one breaks in some other way.
Puan 1
Yorum Ekle
Thanks!!!! This may do the trick.
Puan 0
Yorum Ekle
Same happened to my wife's one. I'm going to try this - https://www.youtube.com/watch?v=CrGsEjH-...
Puan 0
1 Yorum:
Those replacements would absolutely work based on the extent of the damage. In my case, however, the screws ripped out which damaged the side of the actual body and prevented any new band connector from being installed.
It looks like that is what happened to OP as well. The screw studs are completely missing in their photos.
If the same happened to you, don't waste money on replacement connectors as they won't be able to be installed.
tarafından
Yorum Ekle
Thanks for the housing-band reference!
This also happened to my wife's charge4 shortly after the end of the 1y warranty with more than half of the screw holders breaking off from the body.
I used superglue to reattach the connector part & its screws and it held up for a few months but now it broke off again.
Since she's not too thrilled about the look of the housing-bands, I'm considering drilling deeper into the existing screw holes and using longer screws (+glue) so it holds a bit longer. Anyone tried that? Any clue how deep I can drill beyond the side-surface of the watch body before hitting something important?
Puan 0
1 Yorum:
Get serious and get an Apple Watch. They always work and don’t fall apart.
tarafından
Yorum Ekle
@kbembedded thank you so much for the link to the Fitbit off brand holder. I had the exact same problem as OP and my Fitbit has been sitting here unused for over a year. Your recommendation saved it!
Puan 0
1 Yorum:
did u buy it and use it ? how is it
tarafından
Yorum Ekle
  1. Use Rubber Bands or Rubber Gloves: Wrap a rubber band or wear rubber gloves to provide extra grip on the damaged screw and the sleeve. This may help you get a better hold on them.
  2. Apply Lubricant: Try applying a small amount of penetrating lubricant (like WD-40) around the screw and sleeve. Allow it to sit for a while to loosen any debris or corrosion that might be making it difficult to turn the screw.
  3. Use a Rubber Band or Eraser: Place a rubber band or a small piece of eraser over the screw, then press down firmly and turn it counterclockwise. The rubber or eraser may grip the damaged screw and allow you to turn it.
  4. Tweezers or Needle-Nose Pliers: If there's enough of the screw or sleeve left, you can try to grip it with a pair of needle-nose pliers or tweezers. If the sleeves have nibs, try to catch these nibs with the pliers' tips for a better grip.
For more details check my website DK Mart Official
Puan 0
1 Yorum:
There are a number of issues with this response.
#2 is really bad advice. WD-40 (and many other penetrating lubricants) can indeed destroy some plastics and are pretty much all conductive. Spraying it anywhere near a device that is mostly plastic and electronics is a good way to destroy them quickly.
While #1, #3, and #4 are good ideas to remove a screw with a stripped head, that isn't the issue with OP, isn't most of the issues reported here, and isn't most of the issues I've repeatedly seen with FitBits. The actual mounting studs for the screws have ripped off, there are no screws even left.
Also in case anyone reading this who is curious about the link to the website, it's basically a bunch of advertising material for various products and Amazon affiliate links.
tarafından
Yorum Ekle
Yanıtını ekle
Nicholas Wiedeman sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 35
Son 30 gün: 220
Her zaman: 17,156
