Ana içeriğe geç
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
293 Soru Tümünü görüntüle
Do I need the temperature sensor for a hard drive to SSD upgrade?
I have done this upgrade on both a 2012 and 2013 iMac and used the included temperature sensor, but I am seeing mixed answers about whether the mid-2017 iMac needs the temperature sensor when performing a HD to SSD upgrade.
I don’t want to spend $70 buying a kit full of parts I don’t need when I have everything from the previous 2 replacements I’ve done. All I need is the screen adhesive and SSD caddy.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
No, the newer 2014 onward systems running Mojave or newer don’t need it. Apple altered the firmware which is now able to support the newer SMART release which has the better thermal sensor access that wasn’t presently in the older drives so make sure you are using a newer 2019 or newer drive.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Excellent, thank you for clearing that up!
tarafından
Yorum Ekle
Yanıtını ekle
WontUse MahRealName sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 242
