Ana içeriğe geç
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 Soru Tümünü görüntüle
Repair fail for iMac 2007
I opened up my computer so I can clean out the dust and everything.But when I was connecting everything I accidentally
ripped out the grey wire that connects to the airport card.What Can I do and Can I replace it.
Bu iyi bir soru mu?
Puan 0
2 Yorum
@jellybean4_30 did the connector rip on the board or on the cable?
tarafından
@oldturkey03 The connector on the cable.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Ouch! These Coax connectors are a bit tricky to replace, they can be found.
The other option which is how I deal with it, is to replace the full cable! Here’s a source IPEX U.fl MHF 4 Plug RG-0.81 RF Pigtail Coaxial Jumper Cable OD 0.81mm Black Connector 10cm 15cm 20cm 30cm But you need to get to the other end and soldering in the new one.
The other direction is quite drastic but might in the end be easer and cheaper for you. Thats getting a replacement housing! iMac Alu 20" Rear Housing Unit/w Chassis - $17 USD! Then you just need to move things over.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thank You So much @danj I think I will go for the second Option.
tarafından
Yorum Ekle
En Yararlı Yanıt
From your photo it look nearly disconnected. Just snap it back onto the connector on the wi-fi card.
iMac Intel 20" EMC 2133 and 2210 AirPort Extreme Replacement
Puan 2
1 Yorum:
The golden connecter ripped and I can't connect it.
tarafından
Yorum Ekle
Yanıtını ekle
Keshawn Vasugan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 38
