Keycap not properly fixed in its place
Hello
I’m trying to attach UP and Down keycaps, but i can’t get it fixed .. it will pop up.
I have slide the scissor clip in its place.
what could be the problem?
Bu iyi bir soru mu?
Hello
Bu iyi bir soru mu?
Its hard to tell as we can’t see the other cap’s clips fully. Did you damage the cap? Its easy to do if you don’t pop it on properly.
There are two L shaped clips which slide in first, then the U shaped clips over the pins. Note they go in from different directions as they are the same part just turned over!
Bu yanıt yardımcı oldu mu?
Thank you for the reply.
i think the caps are damaged
@samisultan - Here's one source: Up/Down - Magic Keyboard (Type-N) You'll want to ping them to see when they expect to have more parts and they are out of stock right now.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 46
