Ana içeriğe geç
Logitech Dual Action, oyun için tasarlanmış USB girişli bir PC kontrolcüsüdür. Model numarası: G-UF13A.
My controller keeps disconnecting
So basically, I’ve been trying to play games with my controller, and it only SOMETIMES connects, and if it does it’s only for a split second, I think it might be because a bit of the special uhh, whats it called? protective case of the wires is exposed, like the white stuff, it’s from the Kittens I have.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi Joshua!
Basically it means that you need to replace the cable. I would replace it first and see how that goes.
Just get the glue off and de-solder the cable. Make photo’s before you proceed as you need to know which color goes where. It will not be easy to find the cable (part).
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
Sorry but that doesn't help much, I have no idea how to do these things, I think I might take it to my step-brother, he knows how to do these things I think, he is currently replacing the loose battery on my 3DS, so Ill ask him about this and see if he can help me.
tarafından Paylaş
Hi Joshua! Sry for the late reply.. Yes you can ask him to replace it if he is able to find the part.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Joshua Durbidge sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 23
Her zaman: 1,286
