Ana içeriğe geç
Why does my iPhone occasionally restart on its own?
I decied to repair my screen by myself and I managed to pull it off. However, upon placing the screen back on, the phone occasionally restarts, as if I completely powered it off, then held the power button. The phone would also appear to not be able to be charged. Does anyone have any idea what is going on?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
First, if the iPhone restarts then it capture log data. Check that log data and see.Sometime loose contact of battery to battery connector might also show that issues.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
How do I read the analytics?
tarafından
Sorry, I'm not the brightest
tarafından
While the iPhone restarts it captures the analytic log.That can be found on the settings/privacy/analytics & improvements/Analytic data and search the Panic log. If you have any problem follow those instructions will help you to find it in easy ways.
tarafından
Yorum Ekle
Try cleaning all of the connectors between the screen/battery/cameras/logic board with some alcohol and make sure they’re all seated correctly in the sockets. If the phone is still boot looping from here you can try disconnecting things from the board to see if any modular components are faulty. If you unplug everything from the logic board except for the battery and display, and the device is still boot looping, it may be worth trying to reset the device in DFU mode before replacing the battery or screen. If you’ve tried to wipe the board and aren’t able to, you should at that point take the device into a reputable repair shop to get a diagnostic of the problem.
Puan 1
Yorum Ekle
Yanıtını ekle
Ethan Ethan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 31
