Ana içeriğe geç
Konica Minolta tarafından üretilen, 2400,0 dpi x 600,0 dpi maksimum çözünürlüğe sahip standart boyutlu masaüstü renkli lazer yazıcı.
Error 2474 on status
Hello
I have replaced the toner detection sensor yet still get this error code and it states that the toner cartridges need replacing yet they are new. any help/advice would be much appreciated.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Try pulling out the Ink cartridge you replaced. And shutting down the printer then putting the cartridge back in after you restart the printer.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
Thanks for your offer of advice, sadly it didn't work. I still get the message that each colour toner is not installed.
tarafından
Most of the time this happens because the contacts are not clean. Look for a copper or metal contact on the ink cartridge. And be sure they are clean you can use a Pencil eraser to clean them. Then exam where they would touch in the cartidge holder. And clean those contacts. See if that helps.
tarafından
Yorum Ekle
Yanıtını ekle
albert57dean@btinternet.com sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 30
Her zaman: 493
