Ana içeriğe geç
The April 2014 update of the 11" MacBook Air packs refreshed dual-core i5 and i7 Haswell processors and slightly increased battery performance.
100 Soru Tümünü görüntüle
MacBook Air Backlight not Working / connection shorted to ground
MacBook backlight isn't working and after consuming hours of repair content and checking the board I dared to start removing possibly faulty parts from the board, but I'm kinda Stuck.
The first thing that struck me when taking it apart was the connector being broken or burned
My hope was that it was just the cable, so I bought a new one and tested and of course it didn't work
I proceeded some testing and I found the backlight fuse was blown and also the backlight Pins on the LCD connector are shorting to ground.
I was just about to just reassemble the MacBook without screen and just use it that way when I reminded my self that webcam and antennas would be gone then, so I said F it and started removing parts.
I started with the backlight IC (U7701 or LP8550 don't know how it's called the software saiys 7701 but Google only shows 8550 when searching) And also removed the backlight fuse.
However the backlight pins are still shorted to ground and now I'm afraid to remove too many parts that aren't the cause.
Do you have any ideas what could be the cause of the short and what needs to be replaced?
Here are some pics of the board. There's just nothing there that looks burned or damaged to me.
Bu iyi bir soru mu?
Puan 0
2 Yorum
TubeTorials which pins show short to ground? Your LCD connector should come off next.
tarafından
The two backlight pins
Yeah I'm gonna do that, wish me luck
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The Red dot tells us this area got wet! (liquid detector sticker)
Yes, I can see the signs of burnt contacts in your picture. Sadly you'll need to replace the logic board connector. Without the correct tools all you’ll do is damage things. Best to leave this for someone with deeper micro-soldering skills.
Where are you located? nearest country and city.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Oh didn't even notice the red sticker.
So the LCD connector you mean?
Germany, but I'm gonna try it myself the repair price would be more than I paid for the MacBook itself, I just got it for fun
tarafından
Here's the needed part LCD Display LVDS Connector
Using a fine tipped iron carefully lift each data contacts so they are no longer touching the logic board using solder-wick to take the slider away.
tarafından
Yorum Ekle
Yanıtını ekle
TubeTorials sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 175
