Ana içeriğe geç
2.4 veya 2.66 GHz Core 2 Duo işlemcili Model A1347.
random restarts with random kernel. How to troubleshoot?
Getting random restarts and random kernel errors like: mdworker, imklaunchangent, AssetCacheLocato, to UNKOWN and among others.
I did a fresh install quite a few times but same results. I’ve also tried removing one SO-DMM , then the other, different drives, different RAM and essentially it still restarts with random Kernel errors.
Mac Mini mid 2010, 16GB memory , 250GB SSD, macOS High Sierra
Any suggestions?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
What happens when you use an external drive boot up and run your stuff from it?
tarafından
I tried the OEM RAM and it fixed the issue. I guess i was using incompatible RAM. Thank you for the reply Dan
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
RAM is becoming a bigger issue these days as people often put in faster RAM than what Apple spec’ed for the system thinking they would get more performance.
The problem is the speed of the write and access (Strobe) of the data going in and out also needs to be considered besides the JDEC spec: 204-pin PC3-8500 (1066 MHz) DDR3 SO-DIMM. This is the Row Access Strobe (RAS) and Column Access Strobe (CAS). So make sure to use the correct SO-DIMM’s not too slow and not to fast!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Luis sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 19
Her zaman: 322
