Is it possible to replace the charging port?
The charging contacts are getting very damaged and causing inaccurate charging. Is there a way to buy this piece and replace it, how do I replace it? Thank you. Fitbit Alta HR
Bu iyi bir soru mu?
Bu iyi bir soru mu?
if you can access the port and the board it should be possible to replace the charging port.
if you dont have the proper tools, IE hot air station, solder, flux, new port it could be more costly to do it yourself as opposed to sending it to a repair shop.
hope this helps!
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 368
